Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
84 kaw 550 will will not start
Old Jul 19, 2010 | 11:05 PM
alvakado's Avatar
Default 84 kaw 550 will will not start
550 jetski givin to me ..it won't start ..it all most starts with the carb off ..new starter new plugs new fuel .....can anyone help??? thank you
Old Jul 19, 2010 | 11:37 PM
slippery750's Avatar
You could try rebuilding the carb including the fuel pump.
Old Jul 19, 2010 | 11:45 PM
alvakado's Avatar
Thumbs down What!!!
ther is no fuel pump and these carb don't need rebuilding .. thanks any way
Old Jul 20, 2010 | 08:14 PM
Prom's Avatar
Every carb needs to be cleaned brother, just a fact of life. If it "almost starts" with no carb on it then you know the spark is good, so the only x factor is the fuel and the carbs, clean the carbs and see what you got.
Welcome to KF, and dont be an *** when people try to help you
Old Jul 21, 2010 | 11:13 PM
Wow no wonder you are having trouble with it! There is a vacuum operated fuel pump on the side of the carb! FYI 3/4 of the fuel tank is lower than the carb, how do you suspect the fuel travels upward to the carb in your account that does not exist? If there is no carb then that makes it fuel injected of some sort right? NO, that would also require a fuel pump huh? Do us all a favor and delete your KF account to save us the headache of ignorant people like you who don't even know what good advise is. BTW I have owned two of these skis, a 300 and a 750 SXI Pro. Sell it for $20 and cut your losses!
Old Jul 22, 2010 | 02:08 AM
Prom's Avatar
I'm just glad to see someone who knows something about ski's in here, usually I'm answering all the questions and I have never been on one, lol.
Old Jul 22, 2010 | 07:33 AM
alvakado's Avatar
it's all good ....just what i meant that if i pour fuel in the man it wants to start
Old Jul 23, 2010 | 04:47 AM
Prom's Avatar
Pouring fuel in the manifold is not the same as mixing the fuel into the air intake, if it wants to start with fuel poured into the manifold that means that your ignition and timing are good, all you need is for the fuel to be properly mixed into the air. Hope it helps.
Old Jul 23, 2010 | 09:57 AM
alvakado's Avatar
i hope your right your the only guy out here that really gave me a true answer ...thanks for being straight
Old Jul 23, 2010 | 10:35 PM
Yeah because telling you to rebuild your carb and fuel pump in no way suggests you have a carberator issue??? I stand by my last response!
