84 kaw 550 will will not start
550 jetski givin to me ..it won't start ..it all most starts with the carb off ..new starter new plugs new fuel .....can anyone help??? thank you :eek:
You could try rebuilding the carb including the fuel pump.
What!!!
ther is no fuel pump and these carb don't need rebuilding ..:eek: thanks any way
Every carb needs to be cleaned brother, just a fact of life. If it "almost starts" with no carb on it then you know the spark is good, so the only x factor is the fuel and the carbs, clean the carbs and see what you got.
Welcome to KF, and dont be an ass when people try to help you |
Originally Posted by alvakado
(Post 425167)
I'm just glad to see someone who knows something about ski's in here, usually I'm answering all the questions and I have never been on one, lol.
it's all good ....just what i meant that if i pour fuel in the man it wants to start
Pouring fuel in the manifold is not the same as mixing the fuel into the air intake, if it wants to start with fuel poured into the manifold that means that your ignition and timing are good, all you need is for the fuel to be properly mixed into the air. Hope it helps.
i hope your right your the only guy out here that really gave me a true answer ...thanks for being straight
Yeah because telling you to rebuild your carb and fuel pump in no way suggests you have a carberator issue??? I stand by my last response!
