ZX7R - Front Sprocket - Clutch Slave Cyl
Old Apr 12, 2010 | 04:19 PM
runovryou's Avatar
The thing that started all of this was wanting to bring the sprocket setup back closer to stock. I knew this thing was built up for the quarter mile, which doesn't do much for me running on the express way every day. I have been getting about 20 miles p/gal since I got it, which is worse than my Charger! I knew the teeth ratios were modified for low end power, but until I took it apart and actually looked up what stock was I found out that I have been running 2 down in the front, and 4 up in the back! So I'm taking the front back to the stock (16) for now, and going to leave the back as is. I'm hoping I can use my same chain since I'm only changing the front, which [I'm hoping] will only result in a slight difference in length.
I think with a 16 up front, that I might not be turning 7000-7200 rmp's @ 70 mph on the e-way. My round trip to work and home is 63 miles, which was working out to be almost exactly one tank of gas!
Old Apr 12, 2010 | 05:00 PM
runovryou's Avatar
And here she is put together... (pic from last Fall)
Old Apr 15, 2010 | 04:15 AM
nice looking ride. Am jealous
I got approx 43mpg on mine cruising at 80mph though. so your fuel issues are of a concern. You need to go thru your carb settings and do the plug read. 20mpg is horse**** for this ride.
Old Apr 15, 2010 | 04:33 PM
runovryou's Avatar
Thanks for the compliment. I don't want to get into the carbs on this thing! The guy that built this thing says it took him a month to get them dialed in right. I'm hoping with the gear change that I'll notice significant milage gains. If not, I'll get it back to the shop and let the mad scientist get in to it some more. I was trying to find a pic of the carbs but can't find anything right now. They are Keihin Flatslide CR downdraft I believe. Have a warning on the side.. "FOR RACE USE ONLY". Ha, that could be part of my fuel issue too!! I could go back to stock, but I really do love the performance I get out of this bike. I'm just trying to find that happy balance!
Old Apr 15, 2010 | 05:49 PM
Prom's Avatar
The more performance you get the more fuel you will use. Those race carbs probably dont have mileage in mind for those 1/4 mile runs, however if he modified the rest of the system, intake, exhaust, heads, etc., it might take you a while to get a stock set of carbs to match up. Get her back together and ride her a bit. If she still doesnt do what you want you can get everything ready and swap and tweak the carbs on a weekend. I have timed myself at around 30 minutes to get the carbs off, so should be no biggie.
Old Feb 19, 2011 | 09:24 AM
Kaiser's Avatar
Just wanted to leave a quick thankyou to all the guys in this thread. I've just changed my chain and sprockets on my zx7r and reading all of your comments made the whole process a hell of a lot less stressful !!
Incidently, I used a 27mm socket and a cracking bar with all my body weight. You guys were right, it was fairly tight!!
Thanks again.
Old Feb 20, 2011 | 10:52 AM
Thanks again.
Welcome to KF Kaiser
good to hear that KF info was of assistance.
Post up pics of your ZX7
davehayward1
Oct 18, 2009 04:03 AM
davehayward1
Sep 15, 2009 01:40 AM
dennisj
Z1000
Nov 20, 2008 01:20 PM
cyberfunk
May 2, 2008 06:25 AM
scat
Aug 21, 2007 03:06 PM
