zx11
If you have both harnesses you should be able to make it work. Use the harness that goes with the engine if its FI, and everything else should wire up in a similar fashion, you can interchange the dongles pretty easily. But I've never tried it....enjoy!
Unless your engine is junk it'd be less expensive to simply see if the ZX12 pistons fit if the bores are the only difference. In other words it's probably less headache to do a big bore.
alarmman15613
09-22-2006 04:28 AM
