Z650 carbs
Old Jul 17, 2009 | 08:27 AM
Johntee's Avatar
Hola Zbike,
Waited a week for an electronic ignition unit (don't ask) and it's just raining buckets here. I will let you know the result when I have fitted it.
Old Jul 22, 2009 | 02:10 PM
Johntee's Avatar
Hola Zbike,
Put the electronic unit on but having trouble finding someone with a timing gun and the spark looks disappointingly weak. Runs better but still not as smoothas it should be, could be the timing.
Still doesn't start after standing all night, doesn't seem to pull petrol through, I have to remove an air filter and put my hand over it whilst spinning the engine over and then it fires. After that it starts o.k. but after an hour or two, back to the same procedure. Where am I losing the petrol overnight, everything, exhausts, carbs are tight.
Do these engines require a turn on the idle screw first thing to help starting as I seem to be constantly backing the throttle off when the bike is running?
Any ideas?
Old Jul 22, 2009 | 06:03 PM
Zbike's Avatar
I would turn the idle screws out 2.5 turns. Let me think what else could be wrong.
Old Jul 23, 2009 | 01:23 AM
Turn the choke on at start up and verify your float heights.
Old Jul 24, 2009 | 07:12 AM
Johntee's Avatar
Hola Dragone#19,
I can't really figure out how the choke works. There's a lever on the side which operates on all four carbs lifting four plungers. The only way I can get any reaction is to pull the lever fully up, this is the extreme cold start position, and the engine revs at about 4-5 thousand revs, any other position produces no reaction from the engine, no change in engine revs up or down. If I let the lever go the engine cuts out so I have to turn the throttle stop up and then gradually back it off as the engine warms up.
Any idea how it works?
Old Jul 25, 2009 | 03:27 AM
so that should tell you .....you have gummed up carbs and adjustments. Go back to basics again.
Johntee
Classic Sportbikes
Apr 25, 2014 02:17 AM
andyhm
Aug 17, 2012 06:39 PM
mikuniman
Classic Sportbikes
Jun 8, 2012 01:01 AM
dinkie1
Nov 9, 2008 05:53 AM
Robthemanager
Classic Sportbikes
Sep 23, 2007 09:37 AM
