wont crank!
Old Feb 21, 2008 | 09:30 PM
DREW79A's Avatar
Default wont crank!
ihave a 2000 zx12 its been in the garage a couple months. went to crank it battery dead! I try to jump it off jus turns over! Usually win i turn the switch on i hear the pump or injector whine for a second but now i hear i click.Its a fuel injector relay that is clicking. Has it blown a relay. thers 2 relayson it but only one clicks win i turn the switch on. THANKS
Old Feb 22, 2008 | 03:12 AM
Default RE: wont crank!
blown as in not working? Put your meter across the terminals, could have some voltage drop across them. Bad contacts, etc. Or if you are getting the correct voltage to the relay.
Old Feb 22, 2008 | 01:23 PM
Korr's Avatar
open your air box, get spray fuel injector cleaner spay a little try to start it, if it fires relay possibly definate fuel problem, if it doesn't could be electrical
Old Feb 22, 2008 | 01:49 PM
DREW79A's Avatar
ok thanks ill try that. will a dead or low battery make it click. it wasnt doing it until the battery went completely dead then i put a jump box ion it thats win it statred clicking. thanks for the help!
Old Feb 22, 2008 | 04:40 PM
yes low battery can cause many strange problems. i recomend a battery tender in the future,keeps at peek charge.
incabiker
Feb 10, 2016 12:35 AM
DREW79A
Ninja ZX-12R
Feb 24, 2008 03:48 AM
NavKLX
Feb 20, 2008 02:13 PM
KLXrider44
Mar 24, 2006 04:53 AM
