valves
Old Jul 11, 2009 | 01:03 AM
Originally Posted by 327ninja
i have a 2006 ninja zx6r and i was wondering how to tell if the valves need readjusting it just got 12k miles on it any help would be great.
I prefer to check clearances prior to the maintenance recommendations. While checking, gives you some time to check out the CCT. (cam chain tensioner).
Old Jul 11, 2009 | 01:06 PM
327ninja's Avatar
in polk county
Old Jul 14, 2009 | 02:59 PM
williamr's Avatar
Measure the valve clearances with a feeler gauge. Turn the motor so that the bottom of the cam, not the lobe, is over the bucket or tappet and measure gap. Check the correct value with the manual.
Contrary to what's been posted, valves with a screw and locknut adjuster tend to slacken overtime and get noisy because of wear in the rocker arm and in the adjuster. The constant hammering tends to ease the adjuster over time. This tends to be greater than the wear at the valve seat.
Valves with a bucket and shim adjustment are only affected by valve seat wear, and tend to get tighter and quieter.
If you have bucket and shim tappets, use a micrometer to check the actual thickness of any shim that you need to change before calculating the required replacement. Numbers stamped on the shims aren't always to be trusted.
Rob
Old Jul 14, 2009 | 04:40 PM
Zbike's Avatar
And to add to Rob's statment, make sure you log the shim size that you have taken out and put in. This will help on the next valve adjustment and save time.
Old Jul 15, 2009 | 01:05 AM
yuppers as mentioned. Keep a good record
Old Jul 15, 2009 | 01:16 AM
Road Kill's Avatar
welcome aboard
Old Jul 15, 2009 | 12:39 PM
327ninja's Avatar
thanks for all the help guys i'll have to look into all that
thecount
Jun 9, 2006 08:42 AM
rickyzx
May 27, 2006 11:35 PM
M1A1
Apr 17, 2006 07:07 AM
quiklilrex
Aug 22, 2005 10:10 PM
ntence
May 24, 2005 12:33 AM
