throttle cable
Old Feb 23, 2018 | 05:50 PM
saturnsc2's Avatar
Default throttle cable
I just bought a 1978 Kawasaki kz200. it's a museum piece with only 2900 miles on it. I just discovered a problem with it.. when I twist the throttle the engine doesn't respond like the cable is broken, also the throttle doesn't spring back like there's a spring broken. any ideas on what to check? where to check? the owner gave me an extra cable, but this might not be the problem because there's an adjustment where the cable goes into the throttle assembly & when I unscrew it the cable doesn't pull out like it's connected on both ends.
Old Feb 26, 2018 | 01:38 AM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki Motorcycle Forums
texbb
Jun 14, 2016 10:00 PM
asudevil1881
Apr 22, 2007 02:17 AM
bgillette78
Mar 24, 2007 04:07 AM
liltum56
Ninja 250R
Sep 12, 2006 08:39 AM
ZX_9r
Ninja ZX-9R
Jun 24, 2006 05:02 PM
