synchronizing carbs
Old Jul 17, 2007 | 03:23 PM
KIA's Avatar
KIA
Default RE: synchronizing carbs
well i'm glad i only have 2cylinders and i can scrounge up a vacum guage no problem so i'll give it a try this weekend thans for the tips guys
Old Jul 17, 2007 | 05:08 PM
Kohburn's Avatar
ORIGINAL: mmi86
they also have a new Digital sync gauges and the box is only a little bit bigger than a blackberry, they only bad part is you have to cut off your arm to pay for it
you can make your own digital version for cheap if you don't mind scrounging for parts. you can go to a "u-pull-it" yard and get the map sensor out of GM FWD cars (get one per carb) - then a cheap digital voltmeter for about $5 each.
you can wire up the map sensors and leave them in the bike somewhere hidden and out of the way and just leave wires to each sensor at a connector under the rear seat. with 5 volts going to the sensors they will have an output voltage relative to the vacuum and you can read the voltage output on the multimeters.
total cost about 30$
there is even a refference chart for how many inches of mercury each voltage reading indicates.
(DISCLAMER) i've never done this on a bike. I'm new to bikes, but i've been a gear head for a long time and sold my 400whp mid engine 2 seater to get the wife to let me get a bike.
Old Jul 17, 2007 | 08:35 PM
zzrick's Avatar
Kohburn = mcguyver
Old Jul 17, 2007 | 09:36 PM
Notstock's Avatar
ORIGINAL: Kohburn
ORIGINAL: mmi86
shows intelligence!
Old Jul 18, 2007 | 01:09 AM
ORIGINAL: Kohburn
ORIGINAL: mmi86
What is the tolerance using this method? Sounds good
Old Jul 18, 2007 | 01:26 AM
Kohburn's Avatar
the tolerance is pretty darn good if you go the extra step of putting a very fine trim pot (potentiometer) inline on each sensor. then use a couple T fittings and feed all 4 from the same source. then adjust the trim pots untill the millivolt reading from each is the same. From there the range of the reading is :
if you use a manual hand vacuum pump with a gauge on it like you would get at autozone then you can find out the exact voltage to 1/1000 of a volt for a particular vacuum setting.
once its setup its really quite accurate.
Old Jul 18, 2007 | 01:29 AM
Kohburn's Avatar
ORIGINAL: zzrick
Kohburn = mcguyver
lol - thats actually a nickname of mine - you should have seen me on the side of the road at 1am int he middle of nowhere virginia cutting the side out of a dumpster with a pair of tin snips, using a hatchet and a screw driver to pound holes in it and bend it to shape to hold the two halves of my broken (snapped in half) clutch bracket together so i could finish my 7 hour drive home from college.
yeah i've got it still as a suvenier
Old Jul 18, 2007 | 01:59 AM
zzrick's Avatar
ORIGINAL: Kohburn
ORIGINAL: zzrick
Kohburn = mcguyver
Not on your bike right? Because who...but the real macguyver... keeps a set ofsnips in their bike?
Old Jul 18, 2007 | 02:27 AM
Kohburn's Avatar
lol - nope in a car. was about 7 years ago.
Old Jul 18, 2007 | 06:13 AM
lol, I was thinking the same. Where in the hell did the snips fit on the ride?
2001ninjaZX6R
Jan 9, 2007 04:57 PM
markmeinteil
Classic Sportbikes
Oct 17, 2006 05:59 PM
goedertd
750
Jun 9, 2006 09:56 PM
goedertd
750
Jun 9, 2006 09:18 PM
beaupower32
Aug 4, 2005 10:40 PM
