Stallling when cold
Old Oct 25, 2007 | 12:27 AM
cougarkid's Avatar
Default RE: Stallling when cold
Thermostat keeps it up to temp.
Took it to work at noon today (54 degrees out - was 40 this morning)
Died on the highway - had to baby it to the shop.
New fuel filterand on my way.
Runnig much better now.
Mike
Old Oct 25, 2007 | 05:39 AM
hahaha, thought that you already did (fuel filter) that during your carb rebuild/cleaning.
Old Oct 25, 2007 | 11:18 AM
jeffzx9's Avatar
It's always the$2 part that gets you....
Old Oct 25, 2007 | 07:17 PM
RonInFla's Avatar
o.k. real quick...
---too many sensors to name, but, ecm reads hot intake & hot exhaust, shuts down the engine (overheating).
---WATER PUMP not circulating coolant (temp sensor mounted in return line from radaitor) guage reads cold.
---cold engine = cold seals =coolant flow. (all sealed)
---hot engine = expanding seals = leaking seals (usually through the mechanical seal behind the water pump)
P.S. check your oil for white foam (coolant) it's loosing the pressure into the crankcase (usually)
ironcross
Jun 24, 2011 06:18 PM
KLXPRESS
Oct 25, 2008 10:55 PM
TATTOOZIT
Jan 15, 2006 05:53 AM
Marty
Dec 23, 2005 12:29 AM
ryninger
Nov 28, 2005 03:28 PM
