Spark trouble with 98 kx 250\ plase help
Old Sep 29, 2007 | 12:17 AM
whiskey_dangler's Avatar
Default Spark trouble with 98 kx 250\ plase help
I will tell u what Happened, i started my bike and warmed it up , drove about 100 yard, the it died, fealt like i was out of gas, I was not, I check my plug it was Floud, so i put in a new one It neved up high like the gas was stuck on then died, check my plug no spark, put in a new plug, it had weak spark, then i few days later i show a friend it had no spark then showed aother friend it had weak spark. I try i use coil the the guy said worked, I hear its my coil, then other say it my sator, other say its my cdi box, I do not want to go through buy them all . Can any onehelp?
Old Sep 29, 2007 | 12:42 AM
markmeinteil's Avatar
Default RE: Spark trouble with 98 kx 250\ plase help
I'm sure your plug needs to be changed for one. But secondly, I think you have a carburettor problem. It's doubtful any electrical components have failed other than the spark plug. Take a close look at your vacuum lines, and even the fuel shutoff valve.
Old Sep 29, 2007 | 05:15 AM
mmi86's Avatar
hmm UNscrew the sprakplug cap, see if you see alot of copper wires, if you dont cut a very small amout until you do have a fair amout of copper wires then SCREW the cap back on dont pull the cap off or on
Old Sep 30, 2007 | 05:22 AM
ORIGINAL: mmi86
You are talking about cutting back insulation? For a better connection?
Old Oct 1, 2007 | 01:18 AM
mmi86's Avatar
yes sir
Old Oct 1, 2007 | 03:40 AM
dilysi's Avatar
look in the srevis book there should be test prosegers to test all of thoughs parts
MotoGuy
KLR250
Aug 30, 2013 10:51 PM
fgk228
Jun 11, 2009 01:06 AM
johnrhancock
Apr 15, 2009 04:07 PM
Finger Mullet
Jan 16, 2008 08:38 PM
Apollo241
Apr 19, 2007 03:58 PM
