Rear tire rotating in Neutral
Old Nov 26, 2008 | 01:54 PM
rajdeep's Avatar
Question Rear tire rotating in Neutral
Hello friends, I had put my bike on center stand and when I started the bike, the rear tire began to rotate, this does not happen every time. Its a Ninja 1992.
Any thoughts?
Thanx
Old Nov 26, 2008 | 01:58 PM
it's common. no biggie. centrifical forces do it from the motor.
Old Nov 26, 2008 | 07:41 PM
Yeah what he said,,, You can put your Car on a lift and start it in neutral and the drive wheels will turn... Completely Normal...
Old Nov 26, 2008 | 09:52 PM
OMalley912's Avatar
Now see how fast it will go!...j/k
Old Nov 27, 2008 | 03:26 AM
Zbike's Avatar
Yup, my 00 ZX-11 does it too. No biggie
Old Nov 27, 2008 | 08:25 AM
gammac's Avatar
Mostly stops when fully warmed up.
gammac
Old Nov 27, 2008 | 10:02 AM
williamr's Avatar
Gearbox input shaft is being driven, Gear box is full of oil. Oil causes drag and transfers motion to the output shaft.
Likewise, if you pull the clutch in, the oil causes drag between the drive and driven plates. On a hot engine the oil is thinner and drags less.
Put a foot against the wheel and it stops spinning.
btw - you should always use the centre stand. It's much safer than the side stand.
Rob
Old Nov 28, 2008 | 06:18 AM
whitehendrix's Avatar
yup...
wheel408
Ninja ZX-9R
Dec 4, 2010 02:48 AM
86gpz1000
Apr 17, 2010 05:06 PM
fireroad
Jul 13, 2007 09:16 AM
Notstock
May 2, 2006 10:15 PM
Funkdock
Jan 1, 2006 06:39 AM
