Rear tire rotating in Neutral
Hello friends, I had put my bike on center stand and when I started the bike, the rear tire began to rotate, this does not happen every time. Its a Ninja 1992.
Any thoughts? Thanx |
it's common. no biggie. centrifical forces do it from the motor.
Originally Posted by hoedogg
(Post 341854)
Now see how fast it will go!...j/k
Yup, my 00 ZX-11 does it too. No biggie :)
Mostly stops when fully warmed up.
gammac |
Gearbox input shaft is being driven, Gear box is full of oil. Oil causes drag and transfers motion to the output shaft.
Likewise, if you pull the clutch in, the oil causes drag between the drive and driven plates. On a hot engine the oil is thinner and drags less. Put a foot against the wheel and it stops spinning. btw - you should always use the centre stand. It's much safer than the side stand. Rob |
yup...
