rattling sound and wobbling at speed
bad CCT means the chain is lose inwhich case it will flop around and rattle regardless of RPM. Kawi's are known for CCTs going out, so it doesnt hurt to check it
Wobble is bad any way you look at it and needs to be fixed, if it just started you may have damaged something, have you hit any big potholes lately? Check your rim and tires for any damage and check to make sure they are properly balanced and aligned. if the wobble happens only on brakeing then check your rotors too. Is the wobble constant or only at certain speeds?
its wobbling at high speeds like morethan 90~100mph.
The wobble concerns me though. Pull of the wheels, check the static balance, check the tires for condition, and most likely replace the tires and retorque. And as mentioned, check the stem bearings.
