Push-Start?
Old Sep 20, 2007 | 03:15 PM
Kibara's Avatar
Default Push-Start?
Hey guys. So, my 97 ZX-6 decided not to start last night. (The first day I get my M class, and the thing dies...that’s my luck...) Anyways, we where able to push-start it a couple of times last night, and then it worked fine. Could this be a battery issue? I noticed the lights would dim when I tried to start it, but that’s all that would happen. Any ideas on what might be causing this? Thanks a lot guys!
Old Sep 20, 2007 | 03:21 PM
Default RE: Push-Start?
does it turn over? or just do nothing?
Old Sep 20, 2007 | 03:40 PM
sounds like battery to me.
Old Sep 20, 2007 | 03:54 PM
not if its cranking.....just not firing....
Old Sep 20, 2007 | 04:33 PM
Kibara's Avatar
Sometimes ittl crank, but most of the time it does nothing.
Old Sep 20, 2007 | 04:44 PM
ORIGINAL: hoedogg
+1...try a new battery.... (am i allowed to use that hd?)
Old Sep 20, 2007 | 04:52 PM
yes you are certified to use +1's any time[8D]
Old Sep 20, 2007 | 04:56 PM
davehayward1's Avatar
The battery's always a good place to start but you should get a multimeter.
Attach the leads to the battery
Does it register around 12 volts?
ow rev to 4000 RPM
Does it go up to around 14 - 15 volts?
If so - I believe the battery is ok and
the charging system is ok
You'll then have to look at the ignition system
Old Sep 20, 2007 | 06:11 PM
markmeinteil's Avatar
1+ on a battery also.
Test it if you have a multimeter.
Old Sep 20, 2007 | 06:31 PM
Notstock's Avatar
if its older then 5 years it is probably the batt.
