Overflowing carbs. Float valve?
Old Nov 13, 2007 | 12:05 AM
car5car's Avatar
Default Overflowing carbs. Float valve?
I cleaned and installed carbs, used boat rubber pump to fill carbs to start engine. Engine ran for awhile not good, I checked spark plugs- black dry one and black wet another cylinder. I begun removing carbs again and one of carbs was filled to the top!!! OK, no problem, float valve is bad. I removed float chamber and desided to blow in fuel hose to check valves. They seemed fine! I was lifting floats again and again and there was no leak, at least I didn't feel it. Little stick inside valve was moving OK. Carbs look like they were cleaned recently. Could I flood carbs by using rubber pump? If valve is OK I doubt it. Maybe somebody screwed up mixture adjustment? I probably have to do all adjustments and run engine w/o airbox to see what is going on. Any suggestions?
Old Nov 13, 2007 | 01:09 AM
markmeinteil's Avatar
Default RE: Overflowing carbs. Float valve?
Make sure the float tangs are adjusted properly on all the floats. You may have one set too low.
manoacarl
Aug 21, 2011 03:14 AM
mrtwelvevolts
Aug 8, 2008 03:21 AM
madhatter314
Sep 23, 2007 01:26 AM
Dragon
May 6, 2006 07:35 AM
