Oil Leak
Old Oct 4, 2005 | 02:41 PM
Dave2000's Avatar
Default Oil Leak
I have a slight oil leak in the upper end gasket--1997 1500 classic
Advice on using a "STOP LEAK"
Also, can synthetic oil be used?
bEEN READING THE FORUM HERE, ON OIL OVERFILL. I had changed at dealer and I feel he overfilled it. I noticed my recipt and it stated 4 qts. I beleive that is 1 to many. (filter changed) anyway, a month later these small leaks started. Could this had an effect on seals and gaskets. The leak is comming from the top end fromt, underneath the crome cover.
Thanks for the help!
Old Oct 5, 2005 | 11:52 PM
petezzr's Avatar
Default RE: Oil Leak
Is it still over full? Does your bike have a breather that the oil could be coming out of?
Old Oct 6, 2005 | 01:42 PM
Dave2000's Avatar
Corrected the oil level. Not sure about the breather. I will have to check that. Thank you for the response.
Old Oct 6, 2005 | 03:41 PM
petezzr's Avatar
no problem, wish I had more specific advise. I'm not familiar with your bike, so it could be a common thing with an easy fix, or a 'problem' that'll involve more complex repair. Did the leaks continue after the oil level was corrected?
Oh, as for stop leak, I'd stay away...it treats the symptom not the problem, and only temporarily.
ReneeBruke
Ninja 250R
Sep 7, 2006 08:16 PM
cassa63
Aug 17, 2006 09:37 AM
nucci13
Aug 2, 2006 06:34 AM
kawi636
Apr 4, 2006 09:26 PM
Dave2000
Jan 23, 2006 10:35 AM
