NO Start
Old Dec 30, 2008 | 01:08 AM
BLooDyKnuKlz's Avatar
Default NO Start
I have a 2001 Kawi 125 eliminator that I've been trying to get running. It has Fuel and spark but won't start. i checked the timing and the timing is right. The only thing that was out of spec is the compression (90 psi) I think the spec is 130-160 on that motor. But shouldn't it start with 90 psi?
Old Dec 31, 2008 | 12:03 AM
That is a large psi difference in compression numbers. The plug is prolly fouled now. But 90psi is a sign that this engine is in need of help. Or your spark plug is loose.
Old Dec 31, 2008 | 01:35 AM
There is no sign of combustion. BTW you gotta take out the spark plug to do a compression test. My question is...Is 90 psi of compression enough to ignite the air fuel mixture on a one-cylinder 4 stroke engine? Moto Guros please help!
Old Dec 31, 2008 | 04:38 AM
BigRig18Wheeler's Avatar
90 psi should be enuff.....I've had some ol bikes start with less. lol
If you shoot a lil oil in the cylinder, is it same compression? do you have low compression because of rings or valves?
Old Dec 31, 2008 | 06:45 AM
whitehendrix's Avatar
WET TEST FTW BR!!! HAHHHAHAHHA
welcome to KF man.. do a wet test.. if you're not sure what that is, post up.. we'll walk ya tru. REAL easy too.
good luck!
cegusman
Sep 25, 2012 02:08 PM
IQOUTLAW
Mar 23, 2010 02:33 PM
horizonod
Jan 16, 2009 12:11 PM
