NO Start
I have a 2001 Kawi 125 eliminator that I've been trying to get running. It has Fuel and spark but won't start. i checked the timing and the timing is right. The only thing that was out of spec is the compression (90 psi) I think the spec is 130-160 on that motor. But shouldn't it start with 90 psi?
There is no sign of combustion. BTW you gotta take out the spark plug to do a compression test. My question is...Is 90 psi of compression enough to ignite the air fuel mixture on a one-cylinder 4 stroke engine? Moto Guros please help!
90 psi should be enuff.....I've had some ol bikes start with less. lol
If you shoot a lil oil in the cylinder, is it same compression? do you have low compression because of rings or valves?
DirtyHustle
Mar 23, 2014 02:34 PM
