New and need some help!!
Old May 29, 2006 | 02:08 AM
stealthshooter's Avatar
Default New and need some help!!
Hello, I have a 96 ninja ex 250 f I was wondering if anyone had some model specific specs? I was also wondering if you could help me with jetting? I live at 5500 FT elevation and I need to know what jets to use.
Thanks much!!
Old May 29, 2006 | 05:54 AM
kawtippn's Avatar
Default RE: New and need some help!!
Best thing to do is to buy a Dyno Jet KIT.It's got all you need.And go ahead and buy a manual for that specific model.
Old May 29, 2006 | 06:00 AM
walight01's Avatar
i agree, the instructions with the jetkit will tell you if you need to fun different jets at higher elevation and they will be supplied. Getting a service manual is the best thing to do if you ever plan on doing ANY wrenching on your bike. Most maintance on the bike is actually pretty simple once you know how it works.
Old May 29, 2006 | 08:28 AM
BigRig18Wheeler's Avatar
Is this the general specs you are lookin for??
Engine and transmission
Displacement: 498.00 ccm (30.39 cubic inches)
Engine type: Twin
Stroke: 4
Bore x stroke: 62.0 x 41.0 mm (2.4 x 1.6 inches)
Fuel system: Carburettor. Keihin CVK30 x 2
Valves per cylinder: 4
Fuel control: DOHC
Starter: Electric
Cooling system: Liquid
Gearbox: 6-speed
More details Consult a Kawasaki repair manual.
Physical measures
Dry weight: 138.3 kg (305.0 pounds)
Wheelbase: 1,400 mm (55.1 inches)
Chassis and dimensions
Frame type: Diamond high-tensile steel
Front suspension: Hydraulic fork
Rear suspension: Bottom-Link UNI-TRAK
Front brakes: Single disc
Rear brakes: Single disc
Other specifications
Fuel capacity: 18.16 litres (4.80 gallons)
Old May 29, 2006 | 09:34 PM
Thanks for all the info!!
maninthesea
Feb 2, 2010 01:05 AM
ssincity
Jul 30, 2009 08:03 PM
LilMomma
Jun 18, 2009 08:16 PM
twatkins05
Jul 7, 2008 04:33 AM
frrogger1
Mar 9, 2006 08:30 PM
