Need some help Please!
I'm having problems withmy lights! I've checked the fuses, and as much wiring as I can see, but my tail lights and turn signals won't work. I own a '01 ZX9. Any helpful advice is greatly appreciated. Thanx
If all the fuses look good, look for bad connections within the wiring harness. A corroded or loose terminal could be responsible for your problems. If you are good with a multimeter, start from the bulbs, and trace it on back to the main source of the problem.
fredhill032188
Jul 24, 2007 10:47 PM
