Need Brighter Headlight
Old Mar 30, 2007 | 03:18 AM
madgreek's Avatar
Default Need Brighter Headlight
I do alot of night driving and use my bright lights and still feel like i neeed to see a bit more and farther......not sure the wattage im using now....but looking for the cheapest and easiest solution
thanx
Old Mar 30, 2007 | 03:22 AM
gotrice's Avatar
Default RE: Need Brighter Headlight
go to www.hardracing.com and look up your bike. I use the bulbs from there and they are hella bright without any melting of wires or any fuses popping. I had them i my 636 which i ran with both headlights on 24/7. i currently have them in my buell. BRIGHT AS ****!!!!!!!!!!!!!!!
Old Mar 31, 2007 | 08:48 AM
speedracer138's Avatar
ORIGINAL: madgreek
thanx
What bike do you have?
Old Apr 1, 2007 | 08:29 AM
madgreek's Avatar
I have a 98 zx9.....
Old Apr 2, 2007 | 09:32 AM
srobak's Avatar
Same bike as me... you need the bulb from PIAA... I don't remember which one - I will have to pull it out and get you the part number. It is AWESOME... I will do it monday after work in between thunderstorms
Old Apr 7, 2007 | 09:13 AM
srobak's Avatar
Sorry it took me a while to get back on this madgreek - I forgot all about it. It is too dark out right now to pull the bulb, but I will do it tomorrow. Here are a few shots of it tonight though - and dont let the pics mislead you... it is not the off-white color you see in a couple of them... it is a beautiful, brilliant white light... purest white I have ever seen in a non-HID lamp. The first two are low beams, the last is high. varying shutter and flash settings. I will get pix of the bulb tomorrow and also try to take a pic at sunset, which should look a lot better.
[IMG]local://upfiles/576/055A420A2541463CB170D786F786FE54.jpg[/IMG]
[IMG]local://upfiles/576/2BF4D9BC78E049EEB17F5708AF64528B.jpg[/IMG]
[IMG]local://upfiles/576/E82DB8F3FFC14A299C7205193DA367D0.jpg[/IMG]
Old Apr 8, 2007 | 07:03 AM
srobak's Avatar
As promised....
Text on the bulb reads:
PIAA Clear White Bulb H4 12v 60/55W OJV
[IMG]local://upfiles/576/657AC02B674C46C698646F383F99231B.jpg[/IMG]
[IMG]local://upfiles/576/1897E315BA404DBEAD57FA4B2632209F.jpg[/IMG]
AZR
Jun 23, 2014 02:46 AM
Monster Addict
Jun 3, 2013 01:08 AM
Thad-deus Coan
Ninja 250R
Sep 13, 2012 06:11 AM
Savagekilla
May 16, 2008 10:22 PM
Kohburn
Apr 30, 2008 01:47 AM
