mixture screw settings
Old Oct 8, 2006 | 09:36 PM
chris page's Avatar
Default mixture screw settings
hey i have an 86 zx1000 and took the carbs off for cleaning and rebuild whoever had been there before left out the o-rings on the mixture screws anyone know how many turns to set these at? thanks
Old Oct 8, 2006 | 09:52 PM
markmeinteil's Avatar
Default RE: mixture screw settings
My bike for instance wouldn't say in the clymer manual what to set the idle mix screws at. (The manual says the screws are factory set, and should not be adjusted.)After talking and posting about my problem, no one actually had a straight answer. It turns out that on my '81 KZ750 the more you turn the screw out, the leaner the mixture becomes. I was messing with the screw settings for sometime before it finally felt right.
I'm sorry I can't really give you a complete answer myself, hopefully someone else here knows for sure.
Old Oct 8, 2006 | 11:31 PM
chris page's Avatar
the screws were set initially at 3 1/8 turns out but there wasn't any orings in it the factory sealing plugs were removed. thanks though
Old Oct 11, 2006 | 12:30 AM
Live2Ride's Avatar
I think turn them all the way in and then back out 1 1/2 turns
Old Oct 11, 2006 | 06:21 AM
ORIGINAL: chris page
So your manual says that there are O rings?
Old Oct 11, 2006 | 09:11 AM
ORIGINAL: Dragone#19
The carbs on my bike have idle air mix screw O'rings under the screw head.
SoFlaKaw
Sep 3, 2006 09:24 PM
gfoster
Sep 2, 2006 09:36 PM
Bad Bear
Aug 28, 2006 11:28 PM
krntl13
Jul 23, 2006 02:58 AM
ZX_9r
May 13, 2006 06:46 PM
