losing coolant
Old Mar 22, 2008 | 09:52 PM
yellowkow7's Avatar
Default losing coolant
my zx7 is losing coolant into the crankcase. i dont know where it is coming from. does anyone know where to start looking? i recentlyreplaced the head gasket and adjusted the clearances on my valves, but in the process i may have cracked the cam bearing cage (that piese that bolts on over the cams) could that be where the leak is? thanks for the help
Old Mar 23, 2008 | 06:51 AM
BigRig18Wheeler's Avatar
Default RE: losing coolant
Was it losing coolant before you did the head gasket? What year 7?
Old Mar 23, 2008 | 07:21 AM
Compstall's Avatar
Doesn't sound good. If you're not seeing coolant outside the motor you may have to crack it open again.
Old Mar 23, 2008 | 09:23 AM
The caps would have to be all out of whack for you to even consider cracking the cage. Which would be quite noticeable. But that should not be of a coolant leakage concern. So you were leaking at the head gasket prior to this?
Old Mar 23, 2008 | 11:53 PM
yellowkow7's Avatar
i don't think it was leaking before it never seemed like there was a problem until i blew the gasket and started blowing white smoke from the exhaust. i replaced the gasket and now it is losing the coolant
Old Mar 24, 2008 | 04:42 AM
So ,everything was fine, then the head gasket blew..... Engine overheat? If I had to take a best guess, I would say the head maybe warped or cracked. If it was mine, I would pull the head back off, straight edge her, and if that checked good, magnaflux. IMO anyway...
Old Mar 24, 2008 | 11:58 PM
I agree with tearing it down again, check the surfaces, could have been an untorqued bolt or two, who knows. Start over and give it a detailed look/see.
Old Mar 25, 2008 | 12:09 AM
jeffzx9's Avatar
Yup; gotta pull 'er apart and check and re-check everything. Like BigRig says: "Get out the straight-edge." Look for evidence as you dis-assemble.
(Ain't bikes fun?)
407guy
Oct 10, 2023 01:42 AM
Derosian
Ninja 250R
Feb 6, 2008 09:20 PM
2k1w=no$
May 31, 2007 12:51 PM
clickhere
Jun 30, 2005 12:03 AM
