KZ900 Engine Cutting out? Need Fuel Pump???
Old Nov 17, 2007 | 03:59 AM
Default RE: KZ900 Engine Cutting out? Need Fuel Pump???
hmm, thinking basics here. Make sure carbs are clear, all rubbers are clean and no leaks, and a synch with fresh fuel. Oh, I'd prolly change the plugs during this as well. Get a baseline or fresh start as you will.
edit: If the fuel pump is of concern, then test it.
Old Nov 17, 2007 | 03:44 PM
KNEEDEEPKZ650's Avatar
also make sure you check the vent on the gas cap.some gaskets are bad and the tank will build up vacumn.
Old Nov 19, 2007 | 10:23 PM
TattooGun's Avatar
Nothing but frustration.....
I changed all the fuel lines. Cleaned the petcock. Changed the fuel filters. Cleaned the carbs, cleaned the spark plugs (which may need to be replaced.) New gas, and everything I cna think of but the damn thing likes the same. Idles fine. But when I accelerate it tries to cut out. What the hell? I researched a little and found out that the bike doesn't come with a fuel pump origianlly.
Could it be the valves? How can I tell?
[align=left] [/align]
Old Nov 19, 2007 | 10:48 PM
I did not see a fuel pump on the 76 kz900.
Did you synchrinize the carbs yet? At what rpm is it cutting out?
Old Nov 19, 2007 | 11:02 PM
TattooGun's Avatar
I'm not sure how to sync the carbs...I'm still pretty new to this game. I'm learning as I go. There is no RPM guage. I have the original one, but took it off because the bracket was broken. This is a bobber style bike. I guess I could plug the guage back in just to get a reading. But the bike acts like it does it say around 2500 to 3500 RPM's (that's just guessing idle is from 1000 to 1200 RPM's) like it was before.
Now, I can ride the bike. It just have to tweak the choke to get it up to speed. Once I'm going I can leave the choke alone.
Old Nov 19, 2007 | 11:46 PM
Once you know that the synch is good, then you can play with jetting, needles, etc.
Old Nov 20, 2007 | 04:00 PM
dilysi's Avatar
did you cleen your piolet jets and the idle circuts atfer cleening did you blow air through the the passages
seizetheday4eva
May 29, 2013 08:30 AM
Savage
Jul 25, 2011 06:05 PM
sakibomb80
Oct 30, 2010 07:08 AM
