kz1000 coil?
Old Mar 20, 2007 | 11:41 PM
greenhornet's Avatar
Default kz1000 coil?
OK I got new plugs went through the carbs again and now its bogging in mid range but has top end now??I felt the header when I first started it up and the #1 pipe dont get hot like the others do unles you gas it? could the #1 plug not fire good but #4 have good spark? I tried changeing the wire I looked at the spark and it looked weak could this be a coil?
Old Mar 21, 2007 | 02:04 AM
Default RE: kz1000 coil?
So you are saying that #4 spark is better looking than the #1 spark?
Old Mar 21, 2007 | 10:07 AM
markmeinteil's Avatar
Did you check the spark plug gap?
On my KZ, the #1 & #4 plugs fire off one coil, simultaneously, just as #2 & #3 fires simultaneously on the other coil. You probably have a bad wire if there is a weak spark on one plug of the coil pair.
KIA
Jul 9, 2007 06:44 AM
trtle07
Jul 5, 2007 02:36 PM
95zx6rGuy
Jun 8, 2007 01:12 PM
kappa6m3
Oct 16, 2006 08:28 AM
kdogg123
Jul 31, 2006 07:18 AM
