Kx65 barely running, spark issue?
Old Aug 18, 2024 | 05:26 PM
Per's Avatar
Per
Default Kx65 barely running, spark issue?
So my son was running his bike on the track and it suddenly died. Concluded 145 psi compression, spark is existing but probably weak because plug is wet. Tried 2 plugs btw and one new. Tore down the carb and cleaned everything.
Next thing was throw in an ignition coil, not Kawa specific but it still behaved the same way.
​​​​It hasn't been hot in any way so I don't belive it's the stator so right now I'm trying to measure the cdi internally.
I get out of bounds between ground and Ignition coil pins. Can't get a reading on any ohm, not even above 200K.
​​​​​I only get 2 Ohms between pulsar coil and ground.
Anyone have any input on this?
scubiedoo22
Jul 17, 2019 05:17 PM
stevep07120
Jul 20, 2011 01:59 PM
davebrodeur
KX65
Sep 13, 2009 07:54 PM
clay8up
Jun 8, 2007 04:39 AM
greenhornet
Mar 21, 2007 10:07 AM
