klx swimming lessons
Old Oct 11, 2007 | 03:06 AM
pie4foou's Avatar
Default klx swimming lessons
"think i can do it?"
"I dont know mannnn.... its pretty deep lookin"
"screw it, i'm in"
so thats was the reasoning behind trying to drive through almost waist high water. My bike would get going and unless i was flooring it, it would just bog out, i made it through but did i destroy my bike in the process??? its been a few weeks and it seems to be running fine... just wondering what your 2 cents are.....
Old Oct 11, 2007 | 04:41 AM
Default RE: klx swimming lessons
On a hard ride like that, I pulled the carb, plugand airbox for cleaning.
Old Oct 11, 2007 | 06:09 AM
Did you change the oil?
Old Oct 11, 2007 | 06:36 AM
hahaha, and lubed the chain deej
Old Oct 11, 2007 | 10:43 AM
rocketrotary's Avatar
If it's running fine, I would just do all of the above, and try to avoid being in that situation again.
Old Oct 11, 2007 | 12:23 PM
jeffzx9's Avatar
As long as the bike was running when you went thru the water, you're probably ok. If it stopped, I would definitely check the oil and drain it. Ever heard the saying "oil and water don't mix?" They don't.
Old Oct 11, 2007 | 07:20 PM
pie4foou's Avatar
changed the oil and cleaned the air box out..... havnt touched my plugs yet, put it on the list.... thanks peace
Old Oct 11, 2007 | 08:14 PM
jeffzx9's Avatar
Sounds like you've taken the requisite precautions. Your bike should be pretty much good to go.
Old Oct 11, 2007 | 08:22 PM
there is a snorkel mod in the klx section, do a search. maybe that will help in the future
MaximusPrime
Nov 30, 2012 08:22 PM
srobak
Apr 18, 2009 06:42 AM
deej
May 26, 2007 10:06 PM
LittleFella44
Mar 3, 2006 06:04 AM
Gerg
Jun 21, 2005 04:22 PM
