KLR 250-D8 cooling system problem
Old Feb 22, 2017 | 04:34 PM
Deggsy999's Avatar
Default KLR 250-D8 cooling system problem
Hi all, I have Stupid question , one of many I am guessing since I took the KLR to pieces 3 years ago and am now getting round to putting it back together.
Where does the rubber pipe go (what does it connect to) that comes out of the top of cooling system reserve tank. I know that the pipe that comes out of the bottom connects to the radiator just below the filler cap, but cant figure out/ remember where the top pipe goes.
Thanks for any help I receive.
Old Feb 22, 2017 | 06:37 PM
Isn't that simply an overflow tube that should be routed downward and vented to atmosphere?
Old Feb 22, 2017 | 06:51 PM
Deggsy999's Avatar
Hi thanks for your reply IDRIDR , You could well be correct, I must admit that that thought had crossed my mind, I am usually pretty good at either remembering or figuring things like that out. It's just the length of the pipe that is confusing me, its about 3 feet long so it looks like it at least needs to be routed somewhere specific, I was wondering if it needed to be routed somewhere so that it passes above the highest point in the cooling system to prevent any sort of potential syphoning taking place?
Old Feb 22, 2017 | 08:09 PM
Okay, you have me thinking more about it. I think it may route rearward so if it overflows it doesn't drop hot coolant on your foot. I'm kinda guessing here....so take it for what it's worth.
Old Feb 22, 2017 | 08:46 PM
Deggsy999's Avatar
I like your thinking, that would make sense. At this point I don't have any other ideas so I guess it will find out for sure when I eventually get the thing started again, glass is still half full.
Thanks for your replies.
tdupnorth
Jun 23, 2008 09:44 PM
02ninjazx6
May 7, 2008 06:55 AM
dacevoit
ZRX1200
Jun 18, 2007 09:58 PM
alleakhatt636
May 1, 2007 06:27 PM
