KE wont drop into first.
Old Jun 30, 2016 | 02:36 PM
Mkihm11's Avatar
Default KE100 wont drop into first.
Just bought a 1976 KE100 from some guy's barn. I rode her around for a while and noticed among all of the other issues, I cant drop it down into first. I haven't checked the clutch cable adjustment yet as I wanted to make sure Im not missing anything. Thanks!
Old Jul 1, 2016 | 04:11 AM
Adjustment and oil brand/quality. Just mention that because bent components can occur because of it. congrats on the new ride
Old Jul 1, 2016 | 05:19 PM
If you haven't already, check to make sure you don't have the KE100 with the N-1-2-3-4-5 shift pattern, neutral is at the bottom, not in between first and second. Kawasaki had a number of bikes running that pattern, including the H1 500 if I remember right. You are tapping down all the way to neutral. A lot of ATVs used that pattern too.
From a bit of research I understand the N-1-2-3-4-5 shift pattern was used until 1977, going to the 1-N-2-3-4-5 pattern in 1978.
ALifeAquatic
May 29, 2011 03:04 PM
gunguy
Apr 21, 2011 02:50 PM
ClassicMe
Jun 10, 2009 08:24 AM
asudevil1881
Ninja 650R
Feb 7, 2007 04:25 PM
Excidium28
Oct 20, 2006 08:30 AM
