intigrated tail light
Old 04-01-2006, 03:16 AM
05ninjazx6r's Avatar
Default intigrated tail light
i think i am just plain dumb but i cannot get this damn light to work. all i have to do is hook up the positive wires to the yellow ones that are on the light and i cant get it to work...anyone have any clues?
Old 04-01-2006, 04:08 AM
MAD KAW's Avatar
Default RE: intigrated tail light
did you check the wire your hooking up to, to see if theres power going to that wire? if not did you check your fuses? did ground the lights?
Old 04-01-2006, 04:10 AM
gotrice's Avatar
im lost, the yellow wires are for the turn signals and the plug is for the brake light. so what isnt working?
Old 04-01-2006, 04:11 AM
MAD KAW's Avatar
i think he said the lights he's putting in....
Old 04-01-2006, 04:13 AM
gotrice's Avatar
but it says integrated tail light ???????? im still lost
Old 04-01-2006, 04:17 AM
walight01's Avatar
have you tried hooking it up to a volt meter, if not hook it up directly the battery to see if you bulbs even work.
Old 04-01-2006, 04:20 AM
MAD KAW's Avatar
just be carefull when you hook it up to the battery... don't cross the wires.... you could end up buying a second set of lights....[:@]
Old 04-01-2006, 07:51 AM
the light came with two yellow wires one for the left and one for the right turn signal....i plugged the main piece in and i spliced the wires there are grounds to each turn signal and one other wire...i dont really know what to do from there the directions that they gave me didnt do anything...
Old 04-01-2006, 08:39 AM
MAD KAW's Avatar
ORIGINAL: 05ninjazx6r
could you post some pics? maybe we could get a better idea in how to help you...
Old 04-01-2006, 11:58 AM
txredneckmedic's Avatar
if you got the clear alternatives brand....connect the yellow wire to the positive end, clamp off the neg
Quick Reply: intigrated tail light
