intigrated tail light
i think i am just plain dumb but i cannot get this damn light to work. all i have to do is hook up the positive wires to the yellow ones that are on the light and i cant get it to work...anyone have any clues?
RE: intigrated tail light
did you check the wire your hooking up to, to see if theres power going to that wire? if not did you check your fuses? did ground the lights?
im lost, the yellow wires are for the turn signals and the plug is for the brake light. so what isnt working?
i think he said the lights he's putting in....
but it says integrated tail light ???????? im still lost
have you tried hooking it up to a volt meter, if not hook it up directly the battery to see if you bulbs even work.
just be carefull when you hook it up to the battery... don't cross the wires.... you could end up buying a second set of lights....[:@]
the light came with two yellow wires one for the left and one for the right turn signal....i plugged the main piece in and i spliced the wires there are grounds to each turn signal and one other wire...i dont really know what to do from there the directions that they gave me didnt do anything...
ORIGINAL: 05ninjazx6r the light came with two yellow wires one for the left and one for the right turn signal....i plugged the main piece in and i spliced the wires there are grounds to each turn signal and one other wire...i dont really know what to do from there the directions that they gave me didnt do anything... |
if you got the clear alternatives brand....connect the yellow wire to the positive end, clamp off the neg
