Hyper Blinkers, How to Fix!?
Old May 5, 2007 | 02:13 AM
fms1day's Avatar
Default Hyper Blinkers, How to Fix!?
Okay, what causes blinkers to blink fast? Because at first I thought it was because I've wired the rears but had the front ones off... Causing it to hyper blink because the front ones were not connected to anything.
However, upon mounting my front ones today and wiring them... I test the blink and it still hyper blinks.
Anyone know the reason to hyperblinking? And how to rid it!?
Old May 5, 2007 | 06:00 AM
markmeinteil's Avatar
Default RE: Hyper Blinkers, How to Fix!?
Did you upgrade to LED bulbs? If so, LED's do not have enough electrical load to slow down an electronic flasher. You can buy inline resistors, or a resistor block and that will take care of your problem.
Old May 5, 2007 | 07:38 AM
fms1day's Avatar
No these are regular bulbs.
Old May 5, 2007 | 02:25 PM
itspop1's Avatar
You can install a regular flasher from autozone or pepboys.
I have a ZX12 and replaced the stock lights with a integrated tail and mini lights up front.
Old May 6, 2007 | 03:34 AM
j_christopherhall's Avatar
When that problem occurred to one of the indicator lights on my car the repair shop told me all she needed was a new bulb and that apparentlysolved the problem. Hope that's all it is.
Old May 6, 2007 | 08:13 PM
fms1day's Avatar
Perhaps it's the difference between the four bulbs? I think they're the same. But I'll double check all four (fronts and rears) and ensure that they are the same type of bulbs.
Old May 7, 2007 | 02:48 AM
superninja600's Avatar
It is just the bulb man... just like in cars when the bulbs about to go it'll blink faster and faster.. just replace your bulb for 2 bucks from autozone and your problem is solved
Old May 7, 2007 | 02:54 AM
ohms law bro. Do that figure first.
Old May 12, 2007 | 07:35 PM
fms1day's Avatar
I found out why it was hyperblinking. The rear turn signals were aftermarket and came with three wires... since the bulb had two light-up wires within. Hooking it to one wire caused it to hyperblink while moving it to the other wire fixed it. Funny.. But glad it's solved. All fixed that to you guys and the direction you guys pointed me in.. Thanks!
Old May 12, 2007 | 09:49 PM
Congrats on the fix and letting us know of why.
evil636
Jul 27, 2007 08:13 PM
dreamsign
800, 800 Classic & 800 Drifter
Apr 3, 2007 01:45 PM
rgt71
Apr 3, 2007 01:42 PM
cadams
Aug 12, 2006 04:03 AM
arrowwhead
Jan 9, 2006 07:26 PM
