help bike wont start
Old Mar 30, 2010 | 03:07 AM
andrewthomas's Avatar
Default help bike wont start
2006 zx6rr it was running find and i shut it off other day and now it wont start
look at video for problems
http://vimeo.com/10504321
Old Mar 30, 2010 | 03:43 AM
95451's Avatar
Welcome to Kawasaki Forums.
Alot of good memebers here that should be able to help.
sometimes it take longer then others. so hang in there
Old Mar 30, 2010 | 04:31 AM
thanks
im tight on $$ right now so im trying to find out what it could be and then have my friend come fix it instead of paying for towing and then shop costs and be without a bike for a whole month
Old Mar 30, 2010 | 04:32 AM
Prom's Avatar
My net is too slow for the video, so I cant help ya tonight. I'll look into it tomorrow, odd that it was working and now it isnt, battery maybe? Did you fill it up the day you parked it? Sorry I cant help, good luck and let us know what you find. Welcome to KF!
Old Mar 30, 2010 | 06:19 AM
its not the battery and not sure its the fuel pump, someone says its stick in relay or something not sure, but please check the video
Old Mar 30, 2010 | 07:20 AM
hahaha, sorry for the laugh. That is frickin loud....Your indicator lights are out of whack as soon as the ignition is turned on. Just not sure how a fuel pump relay would cause a dash light issue. A voltage drop or a bad ground??? Better get your meter out and start testing. Good luck
Old Mar 30, 2010 | 01:23 PM
Prom's Avatar
Something is wrong with that thing, lol. It looks like the backlight dims at the same time as the fuel pump cutout, possibly a momentary interuption in the powersupply. Could be a fault in the wiring or a bad sensor, check the ECU your bike should have a self diagnosis, if you cant find anything your going to have to check every inch of your electrical system. My best guess is that the computer is recognizing a serious problem and shuting down then restarting....and now that I think about it that would make it tough to do a self diagnosis huh? Let us know what you find, I'm curious myself now. Good luck!
Old Apr 1, 2010 | 03:04 PM
CDN ZX6r's Avatar
Did you ever install an alarm system on the bike? Or a kill switch? When was the bike running fine last? What led up to this issue? Did anything strange happen to the bike? Did it fall over? Did you add or remove any parts? Something had to cause the problem. I'm in agreement with Prom. The bike could be recognizing a problem, and letting you know. I'd take it to a proper mechanic, and get it checked out right. Why take a risk? Small price to pay for piece of mind.
Old Apr 1, 2010 | 03:13 PM
CDN ZX6r's Avatar
Default $$$$
Originally Posted by andrewthomas
thanks
It might be an easy fix with the right know how and equipment. Find someone with a truck or trailer. (save the towing cost) It shouldn't cost much for them to scan it and tell you what you need. Get an estimate, and then decide if you can afford it or not. That's what I would do. Just a thought.
nathbailey
KX125
Jun 16, 2016 01:35 AM
IQOUTLAW
Mar 23, 2010 02:33 PM
IQOUTLAW
Apr 22, 2009 12:20 AM
bewtew
Feb 17, 2008 08:03 AM
bewtew
ZZR 600
Feb 16, 2008 01:31 AM
