gpz 600r rebuild project
Old May 18, 2009 | 06:43 PM
lankyadz's Avatar
Default gpz 600r rebuild project
Hia all, i have recently bought 2 80's gpz600r 's with the hopes of making one good one out of 2.
the first i bought is a 1989 f reg which was a non runner, the previous owner bought it as a non runner as a project but abandoned it,the engine turns but does not start, it had been dropped on its left hand side. i gave him £200 for it. from what i can see the exhaust studs have sheared, all the fairings are off but complete and undamaged.the exhaust is there but badly scraped
the second one is a 1986 c reg which i bought off ebay for £200 as a non runner mainly as a donor because the exhaust and tyres made it worth its price, this one was a daily commuter at its former home until the engine suffered a problem, the previous owner said the "top end bearing" had gone and he has attemted to repair it but i think he got in a little over his head and he ended up buying a honda (traitor)
i would appreciate any tips and advice you can give me as i would like to get 1 good engine out of the 2 bikes.
i look forward to your replys
Old May 18, 2009 | 08:10 PM
jeffzx9's Avatar
I'd probably begin by getting the '89 motor running or finding out why it doesn't. No reason to do surgery if you don't have to, even if you have spare parts.
Then, start disassembling and label everything (what part, what bike, etc.) Compare the parts for fit, condition, etc. Choose your frame, sub-frame, suspension bits, and engine components, depending on how the engine issue comes out. "Measure twice, cut once," (compare the desired parts for function and fit) and reassemble.
Sounds like a great project! Keep us posted.
Old May 18, 2009 | 08:15 PM
lankyadz's Avatar
will do, i cant wait to get started to be honest, gonna make a start on saturday.
Old May 19, 2009 | 05:13 AM
get some tools for a good diagnosis! You will always have those tools later, so now is the time to plan ahead. I am liking your project.
Old May 19, 2009 | 08:00 AM
lankyadz's Avatar
Default Making a start
I am making a start on it tonight after work, i'm going to start stripping the 86. Organize all the parts and label etc, has any one got any good tips on how to get the header pipes off without damaging the studs please. thanks
Old May 19, 2009 | 12:07 PM
jeffzx9's Avatar
Soak 'em in Kroil or other penetrant lube. May want to heat them if you have a hot heat gun or torch. (Make sure the fuel tank is no-where near!) Use a small stiff bristle brush (tootbrush size, I prefer stainless) to brush off the rust and crud around the nuts and studs first. GENTLY torque on them at first so you can feel if the stud is beginning to shear. Re-heat and Kroil as necessary.
ZX9 Guy
Aug 28, 2013 03:49 AM
ZX9 Guy
Jul 29, 2013 10:06 AM
Bryanxii
Oct 16, 2011 04:38 PM
seth6025
Sep 21, 2011 04:32 PM
turace24
May 12, 2008 04:10 PM
