Engine shuts off as soon as gear is in 1st
Old Apr 2, 2008 | 07:41 PM
sh3llycakez's Avatar
Default Engine shuts off as soon as gear is in 1st
hi i have an '04250.my bike was working fine two days ago and yesterday as i put the bike into first gear, it shut off. when i hold the clutch down, it stays on but as soon as i start to let go of the cluth, it shuts off.i was wondering if it had to do with the kickstand sensor, andhow would i fix it? is the amount of oil relevant to this problem?
Old Apr 2, 2008 | 11:42 PM
markmeinteil's Avatar
Default RE: Engine shuts off as soon as gear is in 1st
Sounds like it's all in your kickstand safety switch. You could try and bypass it. Just connect the wires at the switch together. I bet it would fix the problem. If it were me, I'd just buy a new switch.
Old Apr 2, 2008 | 11:57 PM
Now break it down in terms that you can understand( you just gave yourself the answer). Look in your manual. Look under the clutch section and the clutch safety switch.
Kawi Swag
Aug 7, 2010 05:08 PM
comanche82
Jun 4, 2010 01:15 PM
Bas2thesem
Mar 31, 2008 03:48 PM
OwenSE83
May 9, 2006 02:58 AM
funtoos
Mar 28, 2006 09:30 PM
