engine noise
Old May 14, 2012 | 05:07 PM
edtheun's Avatar
Default engine noise
Every time I take my W800 out for a spin I hear the engine make two kinds of noises. The dominant one is a lowish rumble, like every every motorenthusiast likes and there is a higher pitched ticking sound. At 50 k's ore more it starts to sound like a metal humming bee. It ‘s not that I’m worried, but I’m just curious as to what that sound can be. As soon as I let go of the throttle, the sound is gone. A soon as I open the throttle, the bee is back. The location is on the left side, probably where the injection is placed, so it sounds, but I'm not sure. When the motor is idling, the bee is gone.
Oh yeah, i have an original Kawawindscreen; if anybody is interested, I will sell it for 200 euro incl P&P europe (new 360 euro).
Old May 14, 2012 | 05:27 PM
jeffzx9's Avatar
These pics help?
Is the noise a cam-type "tick" or more like a "buzz" as you describe? I would guess it's in the bevel driveline; perhaps a slight mis-alignment which is torque-sensitive (i.e. under throttle.) Just a wild guess, though.
BTW, sweet bike!!! Welcome to the forums!
Old May 14, 2012 | 07:47 PM
edtheun's Avatar
It's more a buzz-thing and rather high pitched. And certainly on the left side, so that rules out the bevel-driveline. It sounds more like some kind of servomotor. I hope that's an English word. Greetings from the Netherlands
Old May 15, 2012 | 12:25 AM
wow, at first I was thinking vintage until I looked up the new W. A real purty ride.
Review: 2011 Kawasaki W800 - Pipeburn - Purveyors of Classic Motorcycles, Cafe Racers & Custom motorbikes
Not sure on the noise issue. Check the carb airbox resonator?
Old May 15, 2012 | 07:57 PM
jeffzx9's Avatar
Yep; I realize the bevel is on the right. I guess I was referring to the end of the cam on the left side. The bevel setup puts a lot of torque on the 90 degree (upper right side) and wants to "push" the cam. I was wondering if the (left side) end of the cam could be suffering the effects of the "push" and the buzz is related to a loose or worn left-end bearing? (I think it's actually called the "float" adjustment.) Of course, if things were that far out of spec on the left end, they would be equally out of spec on the bevel, itself, and you would hear a nasty whine. I realize it's not a very plausible explanation, but I was concentrating on "things that go buzz" in a bevel drive motor.
Here's a great link for exploded views. Hope this helps.
2011 Kawasaki W800 Camshaft(s)/Bevel Gear Mototech Motorcycle Technology
Old May 16, 2012 | 03:49 AM
ok jeff, my triple duper eye wear is at the shop. But I will have to look up the fiche now since I have no clue yet on this issue.
Old May 16, 2012 | 12:14 PM
jeffzx9's Avatar
(^You're gettin' old, dude....) Ha!
Click on the link and use the "magnifier."
Old May 17, 2012 | 02:06 PM
edtheun's Avatar
Hi guys, thnx for thinking. My bike is at the dealer now and I will keep you posted. But the sound is realy more an sort of electrical buzz/humm than a whining noise. Anyway, I'll keep you posted.
Old May 23, 2012 | 05:11 PM
edtheun's Avatar
Hi everybody,
my mechanic doesn’t think there’s anything wrong and it seems the sound belongs to the this engine. Nevertheless, my problem isn’t solved, because I can still hear it. Admittedly, I am a little picky when it comes to whining and buzzing noises. So I’m thinking of replacing the very civilised peashooterdampers/mufflers with something louder and darker so the buzz will disappear into the background. Can anybody give me some tips/hints? Kwak doesn't have to sound like a Harley, but with a bit more grunt, maybe the sound of the bee will disappear in the background.
Old Jul 8, 2015 | 09:17 AM
enzocav's Avatar
Hi Edtheun,
I know this thread is pretty old, but I have just bought the 2015 Kawasaki W800. It's only done 1000 miles, but basically since I got it, it has made the exact noise you're describing.
It's an electronic buzzing sound coming from the left hand side, near the acceleration rocker, just below the tank.
I have aftermarket exhausts fitted, which are LOUD, and I can hear the noise over them which is seriously annoying on long distances.
What the hell is it!?
