Drive chain problem
Old Jun 16, 2010 | 10:37 PM
Barkas's Avatar
Default Drive chain problem
Hi All. Ive got a Kawa KLE 500, the chain is adjusted to KAWA specs at 35 to 45mm free play, however, when I sit on the bike the chain goes solid rigid and there is zero free play. the bike is a old 1992 model. Someone has told me it could be the mono shock, whatever it is its tearing the splines off my front sprocket as the chain is so tight.... till i get off again ...then it has correct free play.thanks in anticipation.
Old Jun 19, 2010 | 08:40 PM
The shock is easy enough to check. Check your static sag and your rider sag. Your spring may be toast or way under sprung for your weight. A good read http://www.sportrider.com/suspension...ide/index.html
sdloyd
500 LTD
Dec 29, 2024 03:11 PM
rgoers
Apr 19, 2012 08:15 PM
marklambert
Feb 15, 2007 01:24 AM
JB1
Feb 14, 2007 09:32 AM
ZX12Rider
Jun 7, 2005 10:22 PM
