Desperate for an answer...
Old Aug 2, 2007 | 03:04 AM
cierralisette's Avatar
Default RE: Desperate for an answer...
Ok, so here's an update.
I threw a new battery in it, that solved half my problems. Here's a more specific issue now that I can observe it while it's running:
It starts like a champ, idles like a champ. As soon as I rev the throttle and it hits 3-4000 RPMs, the engine dies. It starts to die, and it's almost like the more throttle I give it, the faster it dies.
I'm at a loss...
Old Aug 2, 2007 | 12:19 PM
Kohburn's Avatar
that sounds like the fuel flow is being restricted
Kohburn's Avatar
check your fuel filter (i always forget about those htings)
Old Aug 2, 2007 | 03:52 PM
Notstock's Avatar
when you checked the carbs did you take out the pilot and the mains to see if they were clogged. The mains are kicking in at the higher rpms, so if they are clooged there would be a problem.
Also what about the spark plugs? Pull them and see how they look.
Old Aug 4, 2007 | 02:23 AM
dilysi's Avatar
try reving the motor with the cap open if it gose to red line then you know that the vent is cloged if not than it is in the shutoff
Old Aug 4, 2007 | 09:27 AM
ORIGINAL: Kohburn
yup, basics works wonders at times.
Old Aug 4, 2007 | 07:19 PM
RonInFla's Avatar
make sure that you didn't pinch the vent line closed when you installed the tank. routing of hoses is very improtant. blow air through the vent line with the tank cap open !!!
Vbianco
Feb 5, 2013 02:44 PM
volvo9de40
Ninja 500R
Aug 17, 2008 02:52 AM
Mr.S7
Nov 21, 2006 12:45 AM
evil636
Feb 7, 2006 03:35 AM
Birchmanjr13
Jan 13, 2006 01:56 AM
