Cuts out and pings
Old 10-28-2009, 02:38 AM
daiksan's Avatar
Default Cuts out and pings
More like a pre-ignition fire. IN high gear, at about 5000 RPM, when I need to power up , like a hill or strong head wind. I hit the throttle and total power loss for a second, 2 or 3 times till I drop back on the gas, and it makes a strong ping noise at the head. 98 KLX 250. I ws hoping it was something simple like old fuel, but I tried new , highe octane, and the problem is the same
Old 10-28-2009, 05:37 AM
sounds like a carb tune up to meet your timing and atmospheric conditions at that moment or where you live.
Old 10-28-2009, 01:39 PM
williamr's Avatar
I'd use a strobe to check the ignition timing.
If you don't sort it quickly you're risking a holed piston.
Rob
Old 10-31-2009, 12:12 AM
daiksan's Avatar
Default strobe?
By strobe, do you mean a timing light? I dont think the timing can be adjusted, it comes form a magnito
Old 11-02-2009, 12:43 PM
williamr's Avatar
Even with a fixed magneto timing can move because of wear. If the bike uses a CDI it'll have an ignition curve map.
The other likely possibility is a weak mixture. This will also hole pistons.
Rob
lancer_dancer01
07-08-2014 04:35 AM
lancer_dancer01
Ninja 650R
07-08-2014 04:34 AM
matt62x
09-10-2009 08:24 PM
cruzin
01-12-2006 07:53 AM
Quick Reply: Cuts out and pings
