chain noise and tightness
Old Apr 17, 2008 | 11:24 AM
xyz1000rr's Avatar
Default chain noise and tightness
i thought your chain should only move bout an inch to inch and a half when you press on it but mine makes a lot of noise and i can make it touch the swing arm when pressing up on bottom. i asked at the shop and they said its fine and doesn't need replacement and wasn't to loose. i can tell there is a little tight spot and they said they would tighten it but as soon as it hit that spot it would go back where it was and prob do damage to something cant remember in the front sprocket area. They said it was fine but the noise drives me nuts especially at cruising speed when you can hear it more than engine and my main worry is it coming off and the slap sound when you gun it. I should replace it right or listen to the shop and keep it for a while cuz I'm being paranoid
Old Apr 17, 2008 | 12:35 PM
Kohburn's Avatar
Default RE: chain noise and tightness
a brand new chain won't hurt anything. the chain slack is measured from the top not the bottom. btu there is also a chain stretch measurement detailed in the manual. but the shop most likely would have tried to sell you the work of replacing your chain if you needed it.
Old Apr 18, 2008 | 01:21 AM
BigRig18Wheeler's Avatar
What kind of chain lube are you using?
Old Apr 18, 2008 | 04:04 PM
squidremz's Avatar
When was the last time you cleaned it? You can get excessive noise from a dirty chain...Clean it [sm=smiley20.gif]
Old Apr 20, 2008 | 03:11 AM
a tight link in the chain is not good. Means improper cleaning, lubing and adjustment. Get a complete setup.
Buddy Lee
Mar 9, 2008 05:34 AM
speedracer138
Aug 29, 2007 02:31 PM
ajstockdill
Dec 29, 2006 10:19 AM
SDRRider
Jul 6, 2006 09:00 PM
NavKLX
Jul 6, 2006 03:38 PM
