can i put a 91 kx250 jug, piston, rings. on a 88 kx 250?
Old Apr 1, 2009 | 01:47 AM
jayperpa's Avatar
Default can i put a 91 kx250 jug, piston, rings. on a 88 kx 250?
help!!! i have no $$ and this.. i got 91 jug it bolts on and everything matches...water ports ect..pipe. both bikes share the same bore and stroke..can i order the piston kit for the 91 jug put in onto the 88?
i noticed wiseco.com have diffrent piston part numbers..
everything looks the same even on the inside...help!! i want to ride..im not racing just riding around the house..thanks
Old Apr 1, 2009 | 03:22 AM
OMalley912's Avatar
Usually 3 years is max on the same cylinder for the early 90's. Really not sure, maybe check with the local bike shop and run some numbers. I know back in the day McGrath was running an older jug on his 250 Honda.
Keep us posted on what you find out, the worst that can happen would be cracking a chunk off the top of the piston, scoring the cylinder and maybe messing up the crank. So make sure if you do switch you could just toast the whole engine, worst case senario.
Old Apr 2, 2009 | 01:22 AM
Worlok14's Avatar
I would suggest that you mic the piston and bore to be sure they are the same. Also weigh the pistons to be sure they are the same weight. If they weigh differently, it will vibrate your motor to pieces.
Richard Avatar
Dec 30, 2014 02:34 PM
djchan
Nov 23, 2012 04:50 PM
2007 Green Machine
Apr 19, 2012 12:02 AM
Feral Donkey
Dec 16, 2010 10:14 AM
pitbull419
Sep 25, 2007 01:28 AM
