Brake Lights aren't working correctly.....
Old Jul 30, 2006 | 07:18 PM
DevilGirl's Avatar
Default Brake Lights aren't working correctly.....
My brake light comes on but when you hit the brakes it doesn't get brighter. The wiring is ok and the bulb is ok, I put a new one in. I have a friend that said there is an adjustment **** on the foot brake but I haven't been able to find it. I have a 2004 Ninja 250R. Any help would be greatly appreciated. Thanks in advance!
Old Jul 30, 2006 | 11:26 PM
BigRig18Wheeler's Avatar
Default RE: Brake Lights aren't working correctly.....
There should be an adjustment know on the foot brake, but if the hand brake does the same thing, then I doubt that is your problem.. Are you sure you have the right bulb in there? Did the problem just start?
Old Jul 31, 2006 | 12:30 AM
DevilGirl's Avatar
Yeah just started and I got the new bulb from the Kawasaki dealer here so its definitely the right bulb. Maybe I'll have to trouble shoot wiring or fuses next. Its not the original lights, I got a kit for it. Yes the hand brake does the same thing. Any Ideas??
[IMG]local://upfiles/2531/CE2A4A9A74134189AA895D992D7FDBE1.jpg[/IMG]
Old Jul 31, 2006 | 02:06 AM
evil636's Avatar
Knee Dragging Pimp
double check that its the right bulb, and also make sure the bulb is in all the way, on my new 06 i had one blinker not working, it was in in but it wasnt making contact with the terminals.
Old Jul 31, 2006 | 03:33 AM
DevilGirl's Avatar
It comes on and the connection is good I made darn sure! [:@]
Old Jul 31, 2006 | 04:46 AM
evil636's Avatar
Knee Dragging Pimp
so your getting a running light but no brake, hmmmmmmm are you double positive sure its the right bulb ? if it is and it worked fine before, start checking fuses, flashers and wiring. good luck.
Old Jul 31, 2006 | 06:03 AM
I think there is only one bulb back there for the tail light and brake lamp. Just a standard dual filament dual contact bulb. Like an 1157.... You might double check the bulb. I have seen them bad straight out of the package. You never know. You might also pull the bulb, rotate it 180 degrees, and put it back in..... You might also double check that none of the other parking lamp bulbs on the bike are blowed.. If not, then it is wire chasing time. [:@]
If you have to chase wires, usually it is the ground side that goes out. WHen it is dark out, with the bike running, turn your turn signal on. Does it make any brightness difference in the brake lamp bulb?
Old Jul 31, 2006 | 03:52 PM
DevilGirl's Avatar
I've checked and rechecked the bulb...all the bulbs are good....will check to see if the brake light dims when the signal comes on.....Yep its an 1157 bulb and I bought the two pack and tried BOTH bulbs. No other lights are out I checked. Gonna check fuses next then get the voltage meter out....good thing I grew up with a dad thats an electrician! Plus if worse comes to worse theres a Kawasaki dealer about 5 blocks from me. THANK YOU TO EVERYONE!!!
Old Aug 1, 2006 | 07:07 AM
Well, crap...lol
GL DevilGirl..... You'll have to let us know what it ends up being.
chainslack
Apr 23, 2014 05:11 PM
Jul 3, 2010 07:44 AM
RDHJ
Dec 12, 2009 01:50 AM
toddhalt
Jun 30, 2008 04:35 PM
Nickawasaki
Jun 22, 2007 02:28 AM
