bn125 rpm stays up when throttle closed
Old Jan 23, 2011 | 06:27 AM
namu's Avatar
Default bn125 rpm stays up when throttle closed
I have been asked to look into a problem with 6 2001 bn125s. The RPM stays up to about 3000 rpm when the throttle is shut down. Owners say they were that way new. Carbs were reworked then. The bikes are used in a motorcycle safety class. They have 7 to 8 k on them at 12mph. I was wondering if this is a inherant problem or where to look before exploritory surgery. Any advice on settings or modifications to the stock setup would be smiled upon.
Old Jan 23, 2011 | 11:35 AM
Welcome to KF.
All 6 bikes have this issue, the carbs are all adjusted, the idle speeds are set to 1,300 rpm? You have verified all visuals as cracks and no air gaps in the holders, the cable adjustments are correct and not binding or the rpms are not varying as you turn the bars? Looks like the mikuni BS 28 has a "coasting enrichener" I am not familiar with this carb and it would be nice to know what that enrichener is for, especially since all 6 bikes did the same thing when new. My understanding is that it is for eliminating deceleration exhaust popping but that it can be plugged which may also eliminate your problem as well. Found this pic/explaination while learning. lol Good luck on your research. Let us know what you find as well. Don't forget that the air suction valve and evaporative emission controls are due for inspection and cleaning at 6k miles.
http://www.mychinamoto.com/forums/sh...ng-Jets/page2&
Scorpion
Feb 4, 2015 06:07 AM
Gecko
Oct 6, 2010 06:17 PM
motor_head_666
Sep 13, 2008 12:30 PM
Worlok14
Jul 11, 2008 05:23 PM
Lionfish
Oct 11, 2005 08:20 PM
