Bike won't start (was working before some basic maintenance)
Old Mar 25, 2006 | 01:31 AM
Jutboy's Avatar
Default Bike won't start (was working before some basic maintenance)
Hey guys,
I'm stuck...again...so I did some basic maintenance on my bike and then when I put her back together + turn the key all that happens is the oil and neutral light come on super dim!!! Can you suggest something cause I'm completly stuck.
What I did to my bike which supposedly broke her was
change breaks + tires
cleaned my kill switch connectors (I'm pretty sure I put it back perfect but if this could be causing the problem please tell me)
changed coolant
added a wire so my break light sensor/indicator would pull down.
adjusted my clutch
changed my coolant
fixed my ram-air system which was actually not connected properly
cleaned my air filter
What I did to try to remedy the problem was clean my battery terminals.
I had the battery tested (its a non-maintenance one) about a month ago and it was fine and I hooked it up to a float battery charger which you can see exactly here for the last month
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
any ideas what to do? I'm going to test the battery Monday
Thanks for everything!!!! Jutboy
Old Mar 25, 2006 | 02:38 AM
evil636's Avatar
Knee Dragging Pimp
Default RE: Bike won't start (was working before some basic maintenance)
id say its in the kill switch or the battery connection.
Old Mar 25, 2006 | 05:14 PM
Jutboy's Avatar
oh I just remembered when I put the battery back in there was a small black wire with a yellow tracer which I assumed attached to my negetive terminal.
Oh yeah...my bike is 1997 ZX600F - zx6r
Old Mar 25, 2006 | 09:32 PM
lemac's Avatar
Does it turn over or just the dim lights... sounds like what e636 said or possibly bad ground.
Old Mar 25, 2006 | 10:59 PM
Jutboy's Avatar
I doesn't turn over or even try to, the lights don't go on at all either. All I can see is that the neutral and the oil lights are on...but super super dim...can't even tell during the day but noticable at night.
Did you catch what I said about that yellow tracer wire I attached to my negitive battery terminal. Is that the ground...did I hook up wrong...where should I hook it?
Thanks a lot for the time
Old Mar 26, 2006 | 03:13 AM
lemac's Avatar
was it hooked up b4 if not try disconecting and see what happens, but a good idea would be to get a repair manuel or disc for some refrence.... I'm not a pro at this and I could be wrong so either do that or wait maybe sum 1 else can help or had the same prob.... I know it sux ya wanna get that thing going... hang in there bro hope all works out.
DevilsReject
Sep 14, 2017 02:16 PM
deej
Sep 26, 2008 02:25 AM
DevilsReject
Feb 23, 2007 08:22 PM
Dragone#19
Ninja ZX-10R
13
Feb 19, 2007 05:17 PM
Finger Mullet
Jul 25, 2006 03:04 AM
