big troubles.. help?
Old Sep 5, 2009 | 07:46 PM
skfarq's Avatar
Default big troubles.. help?
98 800cc vulcan......have gas going into the exaust pipes and air cleaner....also dripping from overflow hose....help?
Old Sep 5, 2009 | 07:57 PM
95451's Avatar
Welcome To K.F.
Not sure, But could be the floats in the Carb.
Old Sep 5, 2009 | 09:29 PM
^+1 to the carb having issues. May be some gunk under the valve needle causing fuel to continually run into the engine. This will cause hydrolock and gas in the oil as well. Time for a carb cleaning, adjustments, oil and other maintenance to be done.
Welcome to KF
Old Sep 8, 2009 | 07:26 PM
skfarq's Avatar
thanks for the reply "95451 "and "dragone#19."........YEA YOU ARE PROBABLY RIGHT....BIKE SAT FOR A LONG TIME ,WOULDNT START...HAD FREIND CLEAN CARB,CHANGE OIL,NEW PLUGS....HAS ALITTLE HESITATION TOO(RUNS ROUGH ON LOW END OF GEARS)LOOKS LIKE ITS TIME FOR A REBUILD OF THE CARB...THANKS AGAIN
Old Sep 8, 2009 | 09:53 PM
95451's Avatar
Glad to help
lanky
Nov 18, 2013 04:54 AM
dan_petersen86
ZZR 600
Aug 4, 2008 06:50 PM
csk5000
Jul 17, 2007 02:13 AM
Team FTB
May 26, 2007 02:03 PM
Mott Power
Ninja 250R
Nov 15, 2006 09:27 AM
