95 zx-7 fuel or electrical problem?
Old Jun 20, 2008 | 04:57 PM
swansteve3's Avatar
Default 95 zx-7 fuel or electrical problem?
ok so i still havent been able to figure out whats going on with my bike so i put it in the shop to have the carbs worked cause before it would only run on full choke and would stall out if you touched the throttle so he did the carb work also replaced the plugs and fuel filter he said it runs mint when he has it hooked up to his gas i v bag but as soon as he put the tank and all the hoses running though the fuel pump and everything it runs awful so he had me down there to see what it was doing it runs better than before you can throttle it and it won't die out but it runs awful like it's not getting enough fuel or spark or something and i also noticed that when it was running the tail light is flickering like crazy and sometimes it wouldn't turn over when you hit the starter button they had it hooked up to a booster pak to start it don't know if thats anything or not any help would be great they are having trouble figuring it out as well.
Old Jun 21, 2008 | 04:23 AM
Default RE: 95 zx-7 fuel or electrical problem?
If a full tune up was done ie plugs, carbs, synch, battery, wires, etc. I would think that you should be golden.
Old Jun 21, 2008 | 12:06 PM
swansteve3's Avatar
i would have thought so too the whole tail light flickering and it not wanting to start sometimes when you push the start button wasn't happening before i dropeed it off and i still don't have it back yet i guess thats what i get for taking it to a small shop instead of a dealer.
Old Jun 21, 2008 | 10:32 PM
I would be checking for a pinched wire or a bad connection. If I was that mechanic whom you returned the ride to.
shuohan
Sep 11, 2007 03:12 AM
titan2604
Aug 13, 2006 07:35 PM
mason_rigby
Jun 19, 2006 09:28 AM
TMAN
May 30, 2006 05:25 AM
viper91180
Apr 17, 2006 03:32 AM
