86Ninja 1000R Temp Level Running Hot
Old Jul 17, 2009 | 06:35 PM
Robster's Avatar
Default 86Ninja 1000R Temp Level Running Hot
I have an 86 Ninja 1000R that the temp guage shows it running to almost all the way Hot. It's not overheating, the fan motor works and I put on an alum. blade fan. Heat wrapped the header pipe, flushed the system (twice) and have been running it without the thermostat. It still shows it running hot! I read somewhere that there was a recall on that year bike due to the fact that the resistor wasn't strong enough for the guage? Has anyone else heard of this?? and if so, what size resistor is required to fix this problem?
Thanks to all how reply,
Robster.
Old Jul 17, 2009 | 08:57 PM
jeffzx9's Avatar
Don't run the bike without the thermostat; it's there for a reason. Not sure on the resistor question.
Old Jul 18, 2009 | 01:20 AM
95451's Avatar
Do you have a temp sender or sencor on your bike? If not, They seem to have some Info on that year at this place.
http://www.mcreports.com/Pages/Indiv...-1000-new.html
Good Luck
Old Jul 18, 2009 | 01:34 AM
not sure on the resister, but since you flushed the system, you did verify the pressure test and of the pressure test of the cap?
Old Jul 18, 2009 | 02:44 AM
jeffzx9's Avatar
Good call, Drag. Several posts ago, I included a "recall" link for a wide variety on 2 and 4 wheels. May want to check there. Or, just call a local dealer and ask about a recall on an '86 like yours. They doubtfully would fix it free, but might be able to tell you more details if there was such and what to fix.
Keep us up to date on what you find. It might help another rider.
Old Jul 21, 2009 | 11:37 AM
Robster's Avatar
Thanks all for your help. I asked the shop mechanic about the coolant sensor if a new one would make the difference or not. Problem is they only "heard" about the problem. They don't know how to fix the problem. I will ask my local dealer. I haven't had much luck working with them but I will ask....I will keep you all posted once I find out my next course of action. Thanks for your help guys.
mcwee68
Oct 12, 2015 10:55 PM
dan888
Oct 17, 2011 04:03 AM
kwninja88
Aug 22, 2006 12:59 PM
SERGE
Mar 2, 2006 09:02 PM
TATTOOZIT
Jun 17, 2005 08:59 PM
