84 kawasaki voyager senser problems
Old 02-15-2010, 07:07 PM
84kawasaki's Avatar
Default 84 kawasaki voyager senser problems
my oil senser light comes on and off for no apparent reason. Check oil and oil level buts all that is good. Please help
Old 02-16-2010, 01:50 AM
95451's Avatar
Welcome to Kawasaki Forums.
Hang-in there, alot of good members here.
someone should be able to help soon.
Old 02-16-2010, 05:35 AM
MaverickAus's Avatar
It's sensor.
If the oil level and pressure is good then the problem is either a faulty sensor or perhaps a bad earth to the sensor or some other electronic fault.
Old 02-16-2010, 06:30 AM
Originally Posted by MaverickAus
It's sensor.
true, but I would probably change out the oil filter depending on what mileage you have listed first. ( you omitted this info)
Old 02-16-2010, 07:01 PM
84kawasaki's Avatar
Default Oil Senser Light on 84 Kawasaki Voyager
Ty for your help... I did change out the Oil& Filter and it still has same problem. Light will be on when i start it and drive then somtimes it will not come on when started. Where will i find the senser so i could check it or replace it.. again ty for your help
Old 02-17-2010, 03:28 AM
As Mav mentioned, how was the oil pressure test? Have you verified the sensor being good? Best of luck.
Old 02-18-2010, 07:00 AM
Again it is spelled sensOr not senser. Sorry I don't know the specifics of your bike, do you have a manual?
dgusek
01-19-2010 09:11 PM
dgusek
10-20-2009 09:38 PM
redneckaw12
01-31-2008 06:35 PM
inthechateau
03-03-2007 09:59 AM
lgr12362
03-28-2005 04:22 PM
Quick Reply: 84 kawasaki voyager senser problems
