750R Ninja in Storage
Old Oct 23, 2006 | 09:29 AM
pirate33's Avatar
Default 750R Ninja in Storage
Had my 750R Ninja in Storage in Moms garage for last 4 yrs what all needs to be done to get it running?
[IMG]local://upfiles/3448/C02EA1E4C570464F811BD411B4BA23CD.jpg[/IMG]
Old Oct 23, 2006 | 10:07 AM
markmeinteil's Avatar
Default RE: 750R Ninja in Storage
I'm sure the gas is bad. That's probably the biggest problem you'll have. So you may have to rebuild the carbs if they're gummed up. I'm sure the battery is bad too.
Old Oct 24, 2006 | 04:05 AM
Yup, as mentioned above. Your carb boots are prolly cracked now also and check/replace vacuum lines, check your cush drive on the rear to make sure that they are not all shrunk. Get new tires while you are at it. I would soak the chain in diesel fuel for a couple days also. A long storage sucks.
Old Oct 24, 2006 | 04:49 AM
pirate33's Avatar
Yup plan on new tires(they look great though)battery change oil, coolet, bleed brakes-clutch-clean out gas tank, but what about the engine-is there something I should do before turning over for the 1st time-if need parts who are the companies you guy recomnd for older bikes
Old Oct 24, 2006 | 05:03 AM
I tend to pour diesel down the plug, let it soak, then hand turn it to break the rings. Then change the oil.
Old Oct 24, 2006 | 06:29 AM
GS247's Avatar
Diesel works but I prefer to use marvel mystery oil. It will help lubricate the cylinder walls. Its good stuff.
Old Oct 24, 2006 | 09:12 AM
I would use marvel mystery oil also. You should lubricate your cylinders before startup.
Fogging oil in a spray can, or even WD40 would also work.
Old Oct 25, 2006 | 03:39 AM
I forgot about Marvel Mystery oil.
fjyang
Jan 8, 2010 05:54 AM
bahre2613
Jan 4, 2008 09:54 PM
1984Kawasaki750r
Classic Sportbikes
Aug 28, 2007 05:39 PM
750R87
Apr 13, 2006 07:03 AM
CharlzO
Apr 8, 2006 06:10 PM
